Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rod bearing take a look
Old 07-26-2011, 10:33 AM
67-4-fun 67-4-fun is offline
Originally Posted by CNC BLOCKS NE
A score like that is from debris and its always a good idea to plug the oil filter bypass and use a good filter. And make sure the plug under the rear main cap installed.
If you have one of he blocks with the press in plug under the left head on the rear of the block that has to be removed to clean that galley porperly.
not sure on that, its a 1967 327 block if thats of any help.. I'll just have to look and see what your talking about.. I used a good filter {wix} The oil was high quality { lubercation industries} I think the post above was right about debre from machining that didnt get cleaned. This engine had no more than 12-15 miles on it, it sit more than anything, now i have the chance to do something with it, so id thought on refeshing it up since it sat alot
