Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rod Bearing Wear
Old 03-19-2010, 09:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Looks like a bearing w/a lot of eccentricity to it, or improperly sized rod big ends, possibly a lot of idle speed/low speed use, w/less than optimum oil pressure or excessive cranking w/out start up.
Were both halves the same? If it was more the bottom, you might have had some detonation- especially if the bearings were loose in the cap half when you removed them.
