Rod Bearing Wear - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-21-2010, 01:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Tubbed357
I might haha. But can i run 11:1 on these heads. I dont see why not really but some times i miss things ha
You can run 15:1 w/those heads. Would I advise it? Might depend on the application, and about a hundred other things.
  #17 (permalink)
Old 03-21-2010, 02:48 PM
Did you mix up the rod caps and or change the hole they came out of? They are wearing more on one side . If not that then the rods need to be straightend to make them square to the crankshaft. I would check the wrist pin bushings next but this engine will need a total rebuild that's for sure.
  #18 (permalink)
Old 03-22-2010, 07:09 PM
Tubbed357's Avatar
81 Monte Carlo SBC 357
Nope didnt mix up the caps, they were all stamped. I figured that they could stand high compression. But for 15:1 haha lots of time and money
  #19 (permalink)
Old 03-22-2010, 07:50 PM
How can you get 15-1 compression ratio in a gas engine ? Maybe something else wrong here ?,,have fun
Rod bearing and journal (pics) v8hed Engine 4 11-25-2009 08:51 AM
rod bearing question bracketracer Engine 4 04-06-2009 07:41 PM
Need rod bearing help ASAP! PLZ CustomConspiracy Engine 13 12-01-2008 02:46 AM
Rod length discussion, split from previous thread seriousracer Engine 11 06-29-2007 12:27 PM
Rod ratio RobbieRat Engine 16 11-29-2005 06:52 PM
