Rod Bearings - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2007, 09:18 PM
Rod Bearings
Hey guys quick question here. My new rod bearings from clevitte have an "M" stamped on one half and an "L" stamped on the other. Does it matter which one goes on the rod portion and which one on the cap?? I always thought that rod bearings were identical top and bottom you just need to make sure to line up the alignment grooves.
Thanks for any help here,
Keith
Old 09-12-2007, 12:45 AM
anybody please....
Old 09-12-2007, 05:58 AM
engineczar's Avatar
Are the bearings "P" bearings or "H" bearings and what are you using for a crank, ie: does it have large radius journals?
BSE Racing Engines
Old 09-12-2007, 08:29 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I knew that bearings were thinner at the parting line on each side to allow for the hammering they get....so they won't close up on the journal and wipe the oil off. What I did not know is that they come in different levels of eccentricity. In other words, if you take an old bearing shell and place it like a "U" on a hard surface and beat on the inside of the shell with a ball-pien hammer, it'll curl up like a potato chip. I think I remember it was Smokey Yunick who discovered this and had the bearing manufacturers begin making bearings egg-shaped with the wider part of the shells at the parting line to prevent their curling up or "pinching" and wiping the lube off the journal.
Here's some info from Clevite 77 that helps to explain the "L" and "M" stampings on your bearings.....
"Connecting rods are subjected to high inertia loads at the top of the exhaust stroke when the weight of the piston, rings, wrist pin and top end of the rod are all pulling on the rod cap. This loading tries to stretch the rod and pulls the big end out of round causing it to close in across the parting line. In this case, bearing wall eccentricity provides extra clearance to let the rod flex without having the bearings contact the shaft. Besides low, medium and high eccentricity, Clevite 77® High Performance Bearings are offered with numerous additional features to make them compatible with related parts and suitable for the loads and speeds of competition engines."
The "L" stamp is for "Low eccentricity", while the "M" stamp is for Medium eccentricity. If I'm understanding the above paragraph correctly, I'd install the M bearing shell in the rod cap and the L bearing shell in the main part of the rod.
Old 09-12-2007, 08:48 PM
Good information
383 vs 350 TheCiscoKid Engine 86 05-03-2008 03:10 PM
removing rod end with metal dust cover/spacer cboy Suspension - Brakes - Steering 3 01-24-2006 03:45 PM
5.7" vs. 6" savman1 Engine 30 01-20-2006 09:17 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Rod Length Confusion, Short or Long??? Warrant Engine 11 01-12-2006 02:30 PM
