Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rod Bolt to Block Clearence
Old 04-28-2013, 10:33 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
You need about .050", some use a long zip tie as a guide when grinding. Some ARP rod/bolt combinations will clear. Also check cam to rod clearance, you may need a small base circle cam. Again, depending on parts used.
Do a search in this forum for "rod bolt clearance", you'll find a lot of posts.
Semper Fi
