Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rod Bolt to Block Clearence
Old 04-28-2013, 02:37 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
I would only grind the bolt heads to clear the cam base circle, unless you can't take enough off the pan rails to get your clearance.
Semper Fi
