Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rod Bolt to Block Clearence
Old 05-02-2013, 05:00 PM
oldbogie oldbogie is offline
Originally Posted by ChevroletSS View Post
I took some off the bolt heads so know I can slide a zip tie in between. The pan rails wasnt the issue tho. A little lower was.
Got here too late! The simple solution for stroker clearance is to use the cap screw rod rather than the bolt and nut version. These almost always clear the block and cam without grinding, if grinding is required it is minor and in a less highly loaded area than the bolt head.
Grindeing on rod bolt heads gives me the shivers, I avoid it period. Although I know people who do it, but I can't.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
techinspector1 (05-02-2013)
