Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Site Suggestions and Help
  #1
Old 05-10-2008, 01:05 PM
daddygotrippedoff daddygotrippedoff is offline
Rod bolts SBF
I'm building a 351C motor I had the block boiled out ,new cam bearings and brass freeze plugs. Had the cyls honed out and the crank polished and mic'ed. I bought new rod bolts online and had planed on driving the old ones out and installing the new ones. A mechanic friend told me if I changed the rod bolts I would have to have the rods "resized". Is he correct I've never heard of this. Thanks Karl
Old 05-10-2008, 01:18 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Moderator
 Henry Highrise's barnstar
Wiki Edits: 4
re: Rod bolts SBF
OK.....this forum is for Site Suggestions and Site Help...........Your question really should have been posted over in the Engine forum. But since you are here , I will answer it for you. It would be a good idea to do as your friend says because when you drive the old ones out and the new ones in there is always the possibility of distorting the rod end a bit. So no more than it costs to re-size or true them , I would do it. No need to run the risk of not doing it for the money involved.
Hotrodding is much more than just owning a hotrod...It is a state of mind!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Rod bolts SBF"
383 vs 350 TheCiscoKid Engine 86 05-03-2008 02:10 PM
msa rod bolts? ever used them? 406 ss monte Engine 4 09-27-2005 10:09 AM
Best ways to straighten a twisted repro door? Ripped Body - Exterior 13 07-04-2005 06:29 AM
rod bolts and weight? fireforsin Engine 19 08-31-2004 06:58 PM
replacing rod bolts, Invstr396 Engine 5 10-02-2003 06:56 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
