Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rod&Customs Mustang II IFS question
Old 10-19-2008, 11:30 AM
staleg's Avatar
staleg staleg is offline
Last journal entry: Hand brake
Originally Posted by timothale
to install M II in the Mustang right . you need to add a front sub-frame ... not worth the effort inless you plan to install a hemi or wide cammer engine... most of the suspension loading was in the shock tower area ...the bottom rails of the stock mustang are not strong enough and in an older car could have rusting inside areas that you can't see,,,,Retired Ford Engineer...
Fat Man Fabrications, that are well known for putting a M II under very many different cars, says exactly the same, so they offer some kind of updated strut rod stuff for the classic Mustangs instead.
And one more thing: The 69-70 Mustang are well known as rather nose heavy car, isn't they?
Not what the usual after marked M II kits are made for, I guess...
