Rod&Customs Mustang II IFS question
I have a 1970 Mach 1 I am putting a MII suspension kit in. After reading through some of the posts here I have some reservations about who's kit to use. I liked Rod & Customs kit and was wondering if anyone has any information on them. Good or Bad. Thanks
I can some what understand someone wanting to install a IFS Pinto/Mustang II front end under a older 30's/40's/50's vehicle with out dated suspension but a 1969 Mustang already has a decent IFS under it. The ONLY reason I could see for the Mustang II stuff in a 1969 Mustang would be to eliminate the shock towers.
I believe that the original suspension on a 69 Mustang is stronger than what you are thinking about trying to install.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Must II to old mustang
to install M II in the Mustang right . you need to add a front sub-frame ... not worth the effort inless you plan to install a hemi or wide cammer engine... most of the suspension loading was in the shock tower area ...the bottom rails of the stock mustang are not strong enough and in an older car could have rusting inside areas that you can't see,,,,Retired Ford Engineer...
Russ |
And one more thing: The 69-70 Mustang are well known as rather nose heavy car, isn't they? Not what the usual after marked M II kits are made for, I guess... |
www.meyerbrosrods.com ........Don
The M II conversion
What's there looks good I would still add heavy filler panels for the shock towers, longer sub frame to extend under the front seats,, and a ladder , one rail under the rockers and another reinforcement to the rear box area. lincoln versailles used an additional frame stiffner down the center of the Left and right floor pan, Mustangs with the hi po" K ' engine used heavier gage rockers and the convertibles used an additional flat sheetmetal piece to box the rockers ..I would probably make it look like an old nascar engine cage, curved tubing from the cowl to firewall seam under the fenders to the front sub rails. and a tube under the arear where you bolt on the fenders and beef up the radiator support with cross tubing braces. ...I remember an early protype car that they put on big sticky tires and ran the road race track ...the Radiator support flexed and bent. things moved. ...They original objective was not how strong can the chassis be.. but a 'boulevard ride'
| Mustang II IFS Torque specifications | Marv37 | Suspension - Brakes - Steering | 6 | 07-19-2011 02:50 PM |
| s-10 frame swap or mustang II IFS ??? | 71corvette | Suspension - Brakes - Steering | 13 | 12-19-2007 04:51 PM |
| M II IFS tech question. | staleg | Suspension - Brakes - Steering | 3 | 11-25-2006 09:36 PM |
| Mustang II Booster in a '49 Chevy Question | hiimed | Suspension - Brakes - Steering | 4 | 03-11-2003 07:32 PM |
| Mustang II front end Question | horvath | Suspension - Brakes - Steering | 35 | 03-02-2003 04:08 PM |
