Rod doors - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2010, 08:36 AM
Rod doors
I have used the rod door panels on my 31 ford coupe with great sucsess. The only thing is if your panel has any type of curves to it you have to use a heat gun to try and compensate for this. Such as around hindges or I have a set of safety pin latches that I had fabed into the door which was like a small box on the inside portion of the door, And instead of cutting around this I used a heat gun and allowed the plastic to soften then formed it to fit and it worked out good. As for the duo lock tape it still will not stay stuck to my door so I Used the Christmas tree type push in fasteners and that did the trick. The panel looks great. If you use the duel lock fasteners they will cause the panel to stick out from the door about 1/4 of an inch but the foam stick tape they will give you is the same thickness and you add this to the 3 sides of the panel before you put your material on, Once the material is rapped around and glued you can no longer see the 1/4 gap and they will fit nicely. Just take your time measure 3 times and cut once.
Old 04-03-2010, 08:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welcome to Hotrodders.com
this is the introduction forum.
Your post applies to what question that was asked?
Old 04-03-2010, 03:04 PM
302 Z28's Avatar
Rod Doors is out of business.
Vince
Old 04-03-2010, 03:22 PM
for rod door applications
Rod doors panels? are they as easy as it seems? Streetrodfan Interior 20 01-26-2015 12:09 PM
Junkyard Motors.. Zartan Engine 20 07-08-2011 08:52 AM
Rod Length Confusion, Short or Long??? Warrant Engine 11 01-12-2006 03:30 PM
Rod ratio RobbieRat Engine 16 11-29-2005 07:52 PM
