Rod and Jet for 350 Truck - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-11-2008, 08:14 PM
Mertz's Avatar
Here is an update on my tuning efforts on my 350 power 72 Chevy pickup. I got the timing set (see how much advance is too much) and changed the rods and springs in the carb. It runs great but it used 1/2 tank of gas on a 80 mile trip. Although I was looking for performance it was supposed to be based on economy as well. I haven't pulled a trailer with it yet but I'm sure it won't ping. Everything sounded and ran really good. Spark plugs were tan.
I will be changing back to the stock rods and back to the silver springs and see if the timing changes helped the pinging and the gas mileage.
I found a 17057204 quadrajet and factory aluminum intake manifold here in town for $25. I put the qjet on my 66 Catalina with a 428 and it ran great. The carb was really clean so I didn't do anything to it but put on the adaptor and some sealant on the old gaskets. The idle screws were opened about 6 turns so the idle was at 1400 and off the idle speed screw. I set the idle mixture screws to 1 1/2 turns and it ran fine. I set the idle speed to 800 rpm. Only 15 hg of vacuum but that is what I had with the AFB. The choke opened on its own but I didn't have it connected to anything. I plugged the connection with a hose. How do these chokes work?
I am going to install the qjet on the 350 and see if I can get better gas mileage with the same performance.
Timing is at 12 initial, 35 cent and 51TT.
  #17 (permalink)
Old 05-11-2008, 09:30 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Thanks for the update Mertz! Let us know what happens with your changes.
  #18 (permalink)
Old 05-12-2008, 05:45 AM
hey Mertz,
thanks also for the update....
without a rear wheel dyno all you can do is test/test/test...
for mpg, "if" the plugs are still tan/brown after awhile on the stock 75/47 rods and springs you are not at the max lean A/F yet....
you may want to experiment with the 95 jets and rods sizes combo's.....
(LOL get it lean enough and the motor will drive like it has asthma)
I don't recall anyone on the board doing a Qjet swap with your stock cam/motor/weight combo...
do please post your findings....
  #19 (permalink)
Old 05-12-2008, 09:38 PM
Mertz's Avatar
I put the stock rods back in the carb and it doesn't have a much power or sound as nice but it does appear to be getting better gas mileage. I try a longer trip and see what happens.
  #20 (permalink)
Old 05-13-2008, 06:28 AM
the rods change 75 to 73 was a small change for how much gas consumed to get more pep....
my guess is the springs are the main poor mpg cause.....
CRS=didn't you put the 8hg springs in?....
that will make it run on the rich step sooner and more often when accelerating or a steep hill...(and hurt mpg)
stick some weaker springs in, if they are to weak it will bog and maybe ping on a hill?
WARNING: be gentle with those rods caps screws....they will twist off fairly easy!!!
lol..(now your in the same predicament as me)...my motor wants and likes richer rods...I've still got the lean rods in there for now...
  #21 (permalink)
Old 05-13-2008, 08:57 AM
Mertz's Avatar
On the latest test drive (about 15 miles) I stayed with the stock springs and the stock rods. It had the silver springs when I started all this tuning. I could go weaker if you think that will help. The truck ran fine and had good pickup with no bog. It just wasn't as good at it was with the richer rods. I checked with the shop I get my rods from and they don't have any leaner rods for the .098 jets. The charts shows that if I want to go leaner I need to change to .095 jets. I don't want to take the carb apart to change jets. They also said the springs won't make much difference in mpg. I didn't think that was correct since they would make it richen earlier.
I'm pretty careful with the screws and use a nutdriver with a small grip.
  #22 (permalink)
Old 08-20-2008, 11:15 AM
Mertz's Avatar
UPDATE
I finally got a chance to go on vacation and pull my trailer. The truck performed very well. There was no pinging and it pulled the 7% grade at 40 mph without me stepping into WOT. Gas mileage was down to about 10 when pulling but better when just cruising up and down the river looking for trout. Gas mileage probably has a lot to do with having to use ethanol in the gas.
Thanks for everyones help.
  #23 (permalink)
Old 08-20-2008, 11:50 AM
LOL
my "update"
price of gas dropped about $.25....
that was all the excuse I needed for putting the thinner rods (richer/less mpg) back in and have the "instant" pedal response I really do like....
glad to hear you and the truck are doing well
Re: Ram Jet Motors 1ontokid33 Introduce Yourself 2 09-21-2006 03:16 PM
Crate motor- Carb. or Ram Jet 37Rodder Engine 2 10-05-2005 07:56 PM
Ram Jet, Ramport, or StealthRam EFI? Blownolds Engine 0 12-16-2003 08:47 PM
ram jet 350 engines mike bryan Engine 4 01-23-2003 04:37 AM
