rod knock ? again - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2002, 05:45 AM
New Member
Post rod knock ? again
I do believe i have a rod knock.My question is what can cause rod knock and what do i look for.
Do i have too pull engine or can i pull oil pan cover and look at?
Old 11-04-2002, 06:06 AM
Post
are you sure its not piston slap? is the knock realative to your rpms? i had this happen a few months ago. one of my pistons got a little hot and galded up the wrist pin causing it to slap the cylinder wall on each stroke sounding like tap tap tap tap...... i took it apart and replaced it. good to go. back afterwhile.
Old 11-04-2002, 06:43 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
What did you change? Did you change the piston rod bushing,the wrist pin,rings. How was the bore. Im not sure if it was possible to bend the rod slightly. I know others out there will give a lot more input. You can pull the one head and pop out the rod&piston and have a good look at the bore, plus do a really good check. If you didnt replace the wrist pin bushing that will give the slap back in a little time.
Luv the smell of NITRO in the morning.
Old 11-04-2002, 01:50 PM
New Member
Post
new engine about 10000 miles on it bought 2yrs ago
i took oil, pan cover off today crank seems to be loose,i can get play by pushing up and down on harmonic balancer pulling engine tomorrow.
