Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rod and main bearings
Old 03-22-2009, 01:36 PM
327 / 350 hp's Avatar
327 / 350 hp 327 / 350 hp is offline
rods and main bearings
Originally Posted by sledneck307
I am replacing the cam in my bbc I noticed very few metal particles on dip stick from cam lobes going flat. When I inspect the rod and mains what should I be looking for as far as excessive signs of where. I understand the scratches but the part I need to know is if copper is showing dose this mean the bearing need to be replaced. The motor only has about 8000 mi on it but it has been lead footed a lot.
Any advice would be nice
Thanks
Hi sledneck307, High compression and lead foot will show copper . But if scratches down to copper are metal related then you need new brgs. GOOD LUCK jim
