-   -   Rod and main bearings (http://www.hotrodders.com/forum/rod-main-bearings-155438.html)
sledneck307 03-22-2009 11:44 AM
I am replacing the cam in my bbc I noticed very few metal particles on dip stick from cam lobes going flat. When I inspect the rod and mains what should I be looking for as far as excessive signs of where. I understand the scratches but the part I need to know is if copper is showing dose this mean the bearing need to be replaced. The motor only has about 8000 mi on it but it has been lead footed a lot.
Any advice would be nice
Thanks
406 bug 03-22-2009 12:02 PM
Replace the bearings.
sledneck307 03-22-2009 12:21 PM
ok thanks
Is it common for the copper to be showing with this amount of miles.
bondo 03-22-2009 12:38 PM
Originally Posted by sledneck307
ok thanks
Nope,... at 80,000 maybe, but not at 8000 miles...
sledneck307 03-22-2009 12:43 PM
Any ideas what woud cause this. Becides high rpm. 5500 or so not all the time but quite a bit.
327NUT 03-22-2009 01:31 PM
Sure...the cam wiped out some lobes and all of that material was transported throughout your engine by the oil pump. The babbit material that USED to cover the copper on your bearings was basically ground off by X-cam lobes.
Unfortunately it's time to tear the entire engine apart and get everything cleaned, the crank may need to be polished, new cam bearings?? You won't know until you tear it down and inspect everything. Make sure the new engine start up procedure is done with the proper lubricants.
327 / 350 hp 03-22-2009 02:36 PM
rods and main bearings
Thanks
Hi sledneck307, High compression and lead foot will show copper . But if scratches down to copper are metal related then you need new brgs. GOOD LUCK jim
sledneck307 03-22-2009 07:12 PM
Thanks for the advice I havent yet tore it down but when I do this info will help me alot Thanks :thumbup:
k-star 03-23-2009 05:49 AM
bearings
As was mentioned, the entire engine needs to come apart and jet washed.
The cause for the flat cam can be hard to figure out, But you don't want it to happen again.
Let use know all the facts you can about your engine,and the initial start-up. what oil and additive did you use in it???
Led footing WILL NOT hurt the bearings. Correctly built...You can spank that engine like a 4 year old in wal-mart with no problems.
Keith
CNC BLOCKS NE 03-23-2009 06:57 AM
If the oil filter bypass was plugged and a good filter would have been used nothing would have ever gotten to the bearings.
k-star 03-23-2009 07:51 AM
oil
OH no Carl,,,you didn't go there with the plugged bypass... L.O.L.
Keith
CNC BLOCKS NE 03-23-2009 08:01 AM
Keith
OH YA I DID!!!!!!!
Argess 03-23-2009 08:31 AM
Don't most oil filters have an oil bypass? Darned inconvenient, I'd say.
CNC BLOCKS NE 03-23-2009 09:41 AM
We use the NAPA 1061 or the WIX 51061 and we had a circle track customer tear 4 dist. gears in one nite and at the end of the year took the engines apart and there was not a mark on anything as the filter did its job and with the 20/50 oils we use the bypass would have been bypassing oil.
k-star 03-23-2009 11:08 AM
filter
Originally Posted by CNC BLOCKS NE
OH YA I DID!!!!!!!
Carl, don't forget the part where your just driving up the road and the next second the oil filter just blows up.... man i kill me...L.O.L.
