-   -   Rod & Main Bearings - What Kind to Get for BBC (http://www.hotrodders.com/forum/rod-main-bearings-what-kind-get-bbc-130380.html)
leejoy 12-25-2007 10:44 AM
I'm in the process of tearing my piece of junk apart, and I may need Main and Rod bearings. It's a 454 Hi-Perf Street Motor Application
It appears I have standard size main and rod journals.
What kind of bearings should I get? Never done this before.
Is there a certain brand or material or "type" I should be searching for? I've seen sets of bearings from like $15 up to like $125 - made from different materials and different manufacturers. I don't have a lot of money, so can you please recommend only what is "necessary" not the most expensive all-out-racing bearings please.
thanks
Lee
BOBCRMAN@aol.com 12-25-2007 11:38 AM
For your application any tri-metal type bearing will work.
As for brands. Look for Clevite, Mahle, Fed-Mogul. All are good.
