Rod & Main Bearings - What Kind to Get for BBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2007, 10:44 AM
72NOVA454
I'm in the process of tearing my piece of junk apart, and I may need Main and Rod bearings. It's a 454 Hi-Perf Street Motor Application
It appears I have standard size main and rod journals.
What kind of bearings should I get? Never done this before.
Is there a certain brand or material or "type" I should be searching for? I've seen sets of bearings from like $15 up to like $125 - made from different materials and different manufacturers. I don't have a lot of money, so can you please recommend only what is "necessary" not the most expensive all-out-racing bearings please.
thanks
Lee
Old 12-25-2007, 11:38 AM
BOBCRMAN@aol.com's Avatar
For your application any tri-metal type bearing will work.
As for brands. Look for Clevite, Mahle, Fed-Mogul. All are good.
400 sbc wiping out main bearings race140 Engine 8 08-16-2007 12:53 PM
main bearings hdbiker Engine 2 04-30-2007 07:46 PM
87 Chevy 350 TBI rod & main Clearance question Mustangsaly Engine 3 05-20-2006 04:18 PM
Where can I find rod end bearings... 37Ford Suspension - Brakes - Steering 2 03-20-2003 12:20 PM
.001 oversize main bearings from factory crshrmn3 Engine 2 01-02-2003 07:46 PM
