rod and piston install - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2004, 03:10 PM
406 six speed
On eagle h beam rods i noticed there is a larger chamfer on one side of the big end.Is this for radius clearence?Does the larger chamfer go against the crank , and the smaller chamfers are against each otherr...is this correct.
Old 01-14-2004, 03:15 PM
camaroman7d's Avatar
Yes, the chamfer goes towards the crank and the "flat" side mates with the other rod on the same journal.
Royce
Old 01-14-2004, 08:13 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Ditto. You will also notice the bearing end is not centered with the rod pin end. Rods are very directional.
Chris
Old 01-14-2004, 08:18 PM
406 six speed
Chris
i dont think i understand this statement...could you elaborate.
