Rod Rocket - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2011, 10:16 AM
Rod Rocket
Hi There,
can I fit a 3.875 in stroke crankshaft into a standard sbc 400 block?
If so, is there a large amount of clearancing required ?
Is there a problem with camshaft clearance?
Old 07-12-2011, 10:30 AM
SSedan64's Avatar
Yes, it will fit. I wouldn't go any larger with a Stock 400 Block tho'.
It's only .125" or 1/8" more stroke.
You will have less Cam to Rod clearance, which you will have to check & clearance. A Small Base Circle Cam makes it easier but, isn't required.
Scat has some nice Stroker clearanced 4340 I-Beam Rods that work well.
Old 07-12-2011, 10:49 AM
Rod Rocket
Thanks for that.
Would you anticipate that I will need to relieve the block at all ?
Old 07-12-2011, 10:58 AM
SSedan64's Avatar
Yes, it will probably need slight clearancing in the same spots the Factory clearanced for the 3.75" Crank.
A long Zip Tie works well for checking Cam clearance etc..
This is for a 383 but, you can see where the clearance problems are.
http://www.chevytech.info/2c42o17.html
350 vs 350 rocket American Muscle Engine 36 07-07-2009 08:18 PM
403 rocket eatonde Engine 8 09-04-2008 09:57 AM
p-17 Rocket says Hi Ya All p-17Rocket Introduce Yourself 1 10-30-2007 03:05 PM
I think it's a 350 rocket bobby hudson Engine 5 10-20-2006 07:57 PM
Rocket Car Moby302 Hotrodders' Lounge 2 12-10-2003 03:38 AM
