rods off pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2014, 02:03 PM
beachbum0's Avatar
rods off pistons
I have looked at all the threads on how to press fit pistons together. But how do you heat the rod with the piston on to get them apart? Get the rod bore to expand without heating the piston. I just wanted to deburr and polish and put back together Thanks
Old 03-13-2014, 03:47 PM
beachbum0's Avatar
Thanks . I didn't think before asking. I will press off old ones, buy new pistons, and heet the rod and insert new pin. When pressed off the piston can get scratched but I am replaceing them with new anyway. I was jus wondering about getting them off and saveing everything without damage for onother time.
Old 03-13-2014, 04:07 PM
BOBCRMAN@aol.com's Avatar
You will also need to fab some kind of fixture with a driver and a receiver to avoid rod/pin/piston damage. That's what machine shops are for.. Properly done most pistons/pins can be re-used with no press damage.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
Old 03-13-2014, 09:03 PM
beachbum0's Avatar
thanks all, thought they could be reused.
Old 03-14-2014, 09:37 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Dry ice is sometimes used.
The Following User Says Thank You to 1Gary For This Useful Post:
Old 03-14-2014, 01:26 PM
X2, while I don't like pressed pins if it's a must I much prefer cooling the pins on dry ice to heating the rod before pressing the pin.
Bogie
The Following User Says Thank You to oldbogie For This Useful Post:
Old 03-14-2014, 07:01 PM
LATECH's Avatar
I worked at 2 different machine shops that had a small "kiln" or oven that the small end of the rod was placed in until it was a dull red hot.That expands the diameter of the small end.
Then, quickly pulling it out, you stuff into the piston , and drop the pin in. The piston is in a small jig and has a set stop, that stops the pin when dropped in. When it cools off, it contracts and grabs tight to the pin. No pressing involved, works pretty good. Just an alternative method. Just sayin.
Both methods are perfectly acceptable.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
Old 03-17-2014, 09:49 AM
Dull red being key. This shouldn't affect the temper of the rod. too hot and your screwed. Ive done them around the farm for equipment and such, but if this was my daily driver / hot rod; I'd head to the local vocational school or machine shop. Should be cheap. If the machine shop is full of cars, come back later LOL it may save you a few dollars. Show up with cleaned parts and everything properly marked as well.
The Following User Says Thank You to AutoGear For This Useful Post:
5.7 or 6.0 rods and what pistons? ace 97 Engine 16 05-02-2013 04:15 AM
new pistons. used rods. MikeAhrado Engine 19 08-17-2010 03:18 PM
seperating pistons from the rods bigkevy Engine 5 07-06-2010 09:29 PM
pistons on rods wrong. BadMonkey Engine 3 05-10-2010 07:54 AM
new pistons/rods Don Meyer Engine 9 08-23-2008 01:00 PM
