rods,rockers and studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2003, 02:21 PM
Post rods,rockers and studs
I'm back with a whole new list of questions As I have mentioned before I'm building a 383 stroker that will go in my 69 Camaro. It is healthy but not wild. I bought Dart heads and with the heads I got guides and studs. The studs are 7/16 and it seems my only choice is a very expensive set of roller rockers. Would I be better off buying a set of 3/8 studs and just using stamped rockers? I know for a racing engine the answer would be to use the rollers......but I'm never going to turn 6000 with this engine. Also the guides are raised. Is there a reason to use raised instead of flat guides? And lastly, 5/16 push rods or 3/8??????Pros and cons. Once again, Thank you Kevin
Old 04-07-2003, 05:34 PM
BOBCRMAN@aol.com's Avatar
Post
you bought way more heads than you need if you are not going to turn the motor, you can use the 3/8 studs and stamped rockers, and you can use the flat guide plates, the raised plates give a bit more stability at high rpm and heavy spring load, also go for the 5/16 pushrods in your case, you don't need the extra weight of the larger pu-rods.
Old 04-07-2003, 05:45 PM
PrimeMover's Avatar
Sittin' on top of the world...
Post
Bob's right. With those heads you're gonna have to make some R's before you make anywhere's close to peak horsepower. Don't Dart heads have 220 cc runners? I'd stay with the 7/16" studs and go with atleast a set of Crane Energizer rockers. They'll run around $180
As far as the push rods go, good quality hardened 5/16 push rods will be plenty good enough.
Raised guides help support big valves under high lift conditions.
[ April 07, 2003: Message edited by: PrimeMover ]</p>
Old 04-07-2003, 07:50 PM
Jared's Avatar
Post
Id go with roller rockers. Harland Sharps are good rockers and I think they have a life time warranty. Mine cost me 180.00 and id say there worth it. they are very well built. just my .02 good luck
Old 04-08-2003, 04:08 AM
Post
These Dart heads have 180 cc intake runners. They were recomended by my machinist as being bullet proof. I got a real good deal on them, cheaper than I could have had a set rebuilt. Thanx for the input, Kevin
Old 04-09-2003, 04:29 PM
PrimeMover's Avatar
Post
Kev, a buck eighty ain't so far out of line after all.. I think with your combo, you'll be grabing for second at around 5600. Let us know - will ya?
