Roll bar info - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2007, 07:37 AM
Roll bar info
hinking of putting a roll bar in 39 and found good info on Advance Auot web site title how to build a roll bar great info and pics
Old 01-01-2007, 02:17 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Cool! If you don't have the equipment to bend your tubing with you might be able to get that done at a welding shop or hire them to build the roll bar for you.
Old 01-01-2007, 02:20 PM
We built a cage for my friends 72 Porsche and we hired a shop to do the bending. We made sure to have the measurements perfect (check, check, check again), and had a guy do all the bending.
Then we did the welding/assembly ourselves. It worked out perfect and was very cost efficient.
Old 01-10-2007, 09:25 PM
techinspector1's Avatar
Wiki Edits: 326
I wrote this a couple of years ago. You may find it helpful.
http://www.streetmachinesoftablerock...opic.php?t=217
Old 01-11-2007, 04:36 AM
Thanks very much for that info. ? On the 5th and 6th points. My cab is not choped and my seats are up so I can drive without killing my back,Instead of angleing down from the main bar to the frame could I extend these bars straight out =parallel with cab floor and even with the top of the seat cushion and then angle down after they pass the front door pillar thus giving me and my passenger some side protection or should I angle them down and add an extra bar for the side protection.Could thick wall 2x2 tubing be used in lieu of pipe?
Old 01-11-2007, 09:12 AM
Wiki Edits: 326
I assume you're describing the side bar that runs from halfway up the main hoop down to about where your left foot will be. This bar is designed to keep you in the car in the event the seat/shoulder belts fail. As viewed from the side of the vehicle, it must pass your body between the shoulder and the elbow. You can always run more bars than are called for in the rule book, but you must build the roll bar to the minimums described in the rulebook if you are going to pass NHRA technical inspection.
Thickwall 2x2 tubing is not acceptable if you plan to pass NHRA technical inspection. Minimum size for a roll bar is 1 3/4" OD x 0.118" wall round steel tubing. Minimum size for a roll cage is 1 5/8" OD x 0.118" mild steel or 1 5/8" x 0.083" chromoly.
If you have no plans to pass technical inspection at the drag strip and simply want to afford some protection for you and your passenger, then use any type materials you want to.
I urge you to purchase a NHRA Rulebook. You can get them from www.summitracing.com for $10.
roll bar? Mr. Wormy General Rodding Tech 1 09-29-2006 08:47 AM
Need info about the th350 transmission joe350s10 Transmission - Rearend 1 07-01-2006 09:44 PM
Now a Sway Bar question.... MM in NM Suspension - Brakes - Steering 5 03-13-2006 11:53 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 12:55 PM
Corvette Roll Bar Corvettebrian Interior 3 12-31-2002 03:13 PM
