ROLL Cage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2003, 10:14 AM
ROLL Cage
i want to build my own roll cage does anyone know where i should start, for example where should i weld it to the fram and so on
Old 06-27-2003, 01:11 PM
can you provide us with more details . What kind of car ? What kind of cage do you want 4 point 6 point 8 point. Will you be racing at any sanctioned events ?
Old 06-27-2003, 05:21 PM
its a 88 camaro with t-tops its not for racing or anything and i just want it because i think they look cool?
Old 06-27-2003, 05:22 PM
i didnt mean to put that question mark
Old 06-28-2003, 10:59 PM
Hello, Look around at the local speed shops for Autopower Roll Bars. If none of them carry them then call I/O Port at 1-800-949-5712. They carry them along with many more race related items.
The Autopower bars are bolt in but can be welded in also. They have simple 4 point to full cages.
Old 07-10-2003, 11:26 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I would recocmend buying the pre-welded kits, and just weld them to the frame. A lot less hassle and not that expensive either. Although they are serious pain in the A%% if you drive it at all. It get easier getting in and out of the car when you figure out how to dislocate your joint's!
Old 07-12-2003, 04:57 PM
i have seen this one roll cage with a bar going the side of the seat it didnt go across it like most i dont know how to explain it do you know what i'm talking about
Old 07-16-2003, 11:40 PM
GearHead69's Avatar
'70 Chevelle '70 C10
With the bars going beside the seats it could have been a 8 or 10 point cage.. Here are some pics of a 4, 8, and 10 point cage
4 Point cage:
Old 07-16-2003, 11:41 PM
GearHead69's Avatar
8 point cage:
Old 07-16-2003, 11:44 PM
GearHead69's Avatar
Go to Jegs.com and click on Chassis and Suspension and then "Roll Cages" and click on Jegster for GM and I think they make a cage to fit your application.
Here's the last 10 point:
Old 07-16-2003, 11:48 PM
Sandflea427SS's Avatar
Anything with a throttle
If you just wanna look cool then make it out of exhaust tubing!
Cheaper than steel pipe!
If you really want to look cool then build so much horsepower to require a real roll cage...
THAT IS COOL!!!!
Old 08-26-2003, 02:11 PM
Couldn’t have said it better myself! If you want to be cool, build a car that is fast enough to REQUIRE a cage to pass inspection at the track! Don’t be like all the “ricers” out there. Kinda like a big wing to increase down force on the rear of a front wheel drive car….just gets you the go fast look with no hook. You’ll be cool as long as the car is parked, but when you get stomped by a 4 cylinder, that roll cage won’t look so cool anymore….
