-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   Roll cage ideas (http://www.hotrodders.com/forum/roll-cage-ideas-225685.html)
HARLEY1967 11-03-2012 11:48 AM
Roll cage ideas
I need some ideas for roll cages in a 1967 Nova.
OneMoreTime 11-03-2012 01:27 PM
Moving to General Tech..What you need is the rulebook as there are diagrams for roll cages there to follow and you will have then a legal cage..
Sam
prostreet6t9 11-03-2012 02:34 PM
Do you need a NHRA legal cage for a Certain ET?
There is some pretty good weld together kits out there. Need to know how much cage do you need.
techinspector1 11-03-2012 04:10 PM
There is a rollbar and there is a rollcage.
The determination of which you need depends on the class you will be participating in or the Elapsed Time or Trap Speed you will attain. As a for-instance, a minimum 5-point rollbar with 5-point (SFI 16.1) safety belts is required at 11.49 or quicker. A minimum 6-point rollcage is required at 10.99 if the floor of the vehicle has been modified in excess of 4 square feet (not including tubs) or if the firewall has been altered in excess of 1 square foot. If the floor and/or firewall are unaltered beyond the figures I listed here, then a rollbar is legal to 10.00 E.T. and 134 mph.
A minimum 6-point rollcage is required on all vehicles at 9.99 or quicker and on all vehicles that go 135 mph or faster in the quarter mile.
Pony up 10 bucks and get yourself a NHRA Rulebook.....
Summit Racing® NHRA 2012 Rule Book SUM-NHRARB - SummitRacing.com
prostreet6t9 11-03-2012 04:36 PM
X2 Tech... Our track here in oregon requires a Minimum cage at 11.99 for a full bodied car. You can run 12's all day long but once you get that 11.99 your sent home.
If you need the car to pass tech.. DONT buy your belts until your ready to go racing.
BOBCRMAN@aol.com 11-03-2012 08:52 PM
tips for design http://autoweldchassis.com/opts.invu
prostreet6t9 11-03-2012 09:14 PM
Originally Posted by BOBCRMAN@aol.com (Post 1606646)
Link not working.
BOBCRMAN@aol.com 11-04-2012 08:36 AM
Try this. Auto Weld Chassis Components Racing Manufacturing Chassis Products, 9" Ford Housings, 2x3 2x4 Mandrel Bent Frame Bending Danville PA
I got the other address from their paperwork on the unit for my Stude gasser project. It had many different styles and proper design parameters.
Maybe this site address has the design/install pages somewhere.
techinspector1 11-07-2012 02:44 AM
This is because the belts are dated at the point of manufacture and are dated ahead to compensate for shelf-time at the dealer's store. Depending, you could get belts with dates that aren't even here yet. I used to find belts all the time with dates that were still in the future. On the opposite side of the coin, you can also end up with belts that have very little time left on them because they were on the shelf longer than other belts. What you're payin' for is two years worth of belts, so make sure you get your money's worth.
prostreet6t9 11-12-2012 07:46 PM
Thats why I mention it.. I have race car's come in here all the time that they've spent years building the car and made the mistake of buying the belts early on. They get to the track and they're turned away.
OneMoreTime 11-12-2012 08:16 PM
One of the things the guys can do is get an old set for setting up and fitting and then buy the new belts when they are ready to go racing..Old belts should be cheap as they cannot be used anymore..Just an idea..
Sam
prostreet6t9 11-12-2012 08:31 PM
Very true.. I just feel bad for the guys that are new to the sport and get a little ahead of themselves and have to buy them twice.
