Roll down windows with remote - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2011, 08:36 PM
rlb3's Avatar
If I got one of the kits that make it where you can control your locks with a remote. Instead of hooking it to the locks could I wire it up to the windows? So say if I hit the lock button one window would roll down but if I hit the unlock button the other window would roll down. I just want to be able to roll them down I don't need them to roll back up.
Any help would be greatly appreciated
Old 11-28-2011, 03:58 AM
EOD Guy's Avatar
Yes it would work, but you'd have to hold down the button the entire time, depending on the car. There is a way to put in a timed sircuit ...... way compliced.
Most after market remotes have a aux feature that allows the locks to work as they should and press aux plus unlock allows a diff action to happen. You could add relays to make both windows to roll down at the same time.
Old 11-28-2011, 05:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the driver side window has an "auto down" feature, you could get that wndow all the way down w/just one click instead of holding it down the whle time.
Old 11-28-2011, 04:33 PM
EOD Guy's Avatar
unless the auto-down feature is in the switch etc..... that's why it depends on the car.
Old 11-28-2011, 07:25 PM
75gmck25's Avatar
My 2005 Mustang has the one-touch down feature on both front windows, and it can be controlled by the OEM remote. If I hold the unlock button down on the remote for more than about 4-5 seconds, there is relay that initiates the one-touch feature on both windows and rolls them completely down.
If you have a one-touch down window you should be able to activate it from a spare remote button by using a remote-controlled relay in the circuit to the one touch down feature. On most cars the one-touch down feature is a separate detent on the power window button that requires you to push the button down a little farther.
Bruce
Supercharger Roll,detroit Roll,blower Surge??? chevygirl74 Hotrodding Basics 37 08-22-2012 12:05 PM
Hydraulic Clutch reservoir - remote or not remote if possible? ClassicDriver Transmission - Rearend 6 03-09-2010 05:40 AM
1991 olds 88 front windows roll up very slowly fumplet Electrical 3 08-24-2006 01:10 PM
remote windows wiring? awsum34 Electrical 3 04-27-2006 03:30 PM
remote battery, remote disconnect for fuel pump questions. Jared Engine 1 03-16-2004 10:33 PM
