To Roll or not to Roll
My question is short (the answer might be long): What are the ups and downs of using roller cams? How do I decide to use a roller cam or not? How are they on a street vehicle?
Thanks.
All modern cars have roller cams in their engines so I think you'll be fine with one in your hot rod.
THe rub on roller cams is two things:
First, the cams usually cost a substantial amount more, especially if you're trying to get retrofit roller lifters for a block not originally machined for a roller cam (usually anything pre 1987 or so depending on the manufacturer). Second, roller lifters weigh a bit more and limit RPM unless some pretty heavy-duty springs and associated valve-train gear is used. Do a search on this topic, its been done to death- K |
My car came with a Crane solid roller cammed LS-6 454 big block.That cam got ruined by a lifter that broke,that setup was probably 16 years old with quite a few miles and lots of hard use.I replaced it with a solid roller Comp Cam set,but what I didnt realise at the time is that Comp doesent make their street line cams out of billet steel.I'm rebuilding my engine this year and I will be putting a custom ground billet roller cam in.A couple of things to keep in mind are dont use oil restrictors or crank scrapers,roller lifters get their oil from the oil galleries as well as from crank windage.Use top quality roller lifters,Isky is offering a no needle bearing option on their Red Zone lifters.You must also use the correct distributor gear ,the wrong one will wear out very quickly.Cam travel must also be controlled,a cam button between the cam and the timing chain cover and a thrust washer between the upper timing gear and the block should be used.The correct springs for the cam are a must,as well as top quality pushrods,screw in rocker studs are a good idea too.Theres probably more that I've forgotten,but hopefully this will give you a better picture.
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| Is this the end time? | USA1 | Hotrodders' Lounge | 307 | 07-11-2005 06:25 PM |
| door panels, roll cages, and seats | REKRAP | Interior | 4 | 11-06-2004 02:44 PM |
| roll bar? | hotrod66_57 | General Rodding Tech | 5 | 08-15-2004 12:10 PM |
| Roll Bars vs. Roll Cages ???? | Barz51 | Hotrodders' Lounge | 13 | 01-06-2003 04:21 PM |
