Roll Over Valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2010, 09:48 PM
Roll Over Valve
The car:
1990 Corvette.
The problem:
I'm eliminating the stock ECU completely. The charcoal filter is controlled and it purges by ECU command.
The solution:
Roll Over Valve
How?
Anyone know how and where to install a ROV on a 1990 Corvette.
67 Camaro -Valve Train noise after Build RMoore2225 Engine 15 08-17-2015 11:51 AM
David Vizard's Idea of Almost Bottoming Hyd. ? BUFFALOBILLPATRICK Engine 46 06-24-2010 02:25 PM
GM Beehive Springs MI2600 Engine 9 06-21-2010 07:32 AM
Piston notching for valve relief/clearance OHD Engine 9 09-16-2008 10:27 AM
Adjusting olds rockers .... HELP A/G WILLYS Engine 7 08-21-2008 12:22 PM
