Roll your own spark plug wires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2012, 08:11 PM
Hey everyone,
I want to make up a set of the old school transparent red spark plug wires. They are solid core and I had a couple questions..
1 Will solid core wires damage a Davis DUI with a flamethrower coil?
2 How many feet of wire will I need for a SBC?
Thanks
Old 10-27-2012, 08:41 PM
techinspector1's Avatar
Wiki Edits: 326
Solid core will play hell with electronic stereo equipment, but I don't know about messing with the coil. My best guess would be no. Call the mfg and ask them....
PERFORMANCE DISTRIBUTORS
2699 Barris Drive
Memphis, TN 38132
901-396-5782
Not sure how many feet of wire to do a SBC. What I would do, if you don't have a set to measure, is go down to the boneyard with a pad, pencil and tape measure. Pull the wires off a derelict that has the wires routed properly and measure them.
A bird's-eye view standing at the front of the motor will have #1 at about 5:30 on the cap.
Old 10-28-2012, 08:16 AM
Wiki Edits: 27
Header heat.
When I was in college years ago I worked in a dealership, A guy had the red wires on his 60 corvette, when I put it up on the hoist, to clean and readjust the floor shifter the red plastic had started melting, plastic dripping off the wires.
Old 10-28-2012, 08:23 AM
delawarebill's Avatar
plug wire
i'm using solid wire on my bucket.. let me say its really stranded wire and is not a resistor types.. needless to say i don't have a radio in my bucket so i don't care if it messes up the radio of the car next to me.. i have used a flamethrower coil.. but i forgot to put in a ballast resistor and smoked my pertornix ign. i replaced the ign and bal res and went back to orig coil...
Old 10-28-2012, 11:32 AM
I run solid core (actually stranded) copper wires and non-resistor plugs in a '64 Corvette with no metal firewall for shielding and much of the wire shielding (used on Corvettes) removed. It also has a Mallory HyFire IV CD ignition and high performance coil. I even solder the ends of the wires to the terminals for the best current transfer.
This plays havoc with the old radio's AM but has little effect on FM. I can't even use my old-style G-meter in the car, even on its own 12 volt battery power supply, as the display just goes haywire and shows gibberish. But my MP3 player and its FM radio (plugs into the power amp) have no problem.
BTW, Mallory recommends that if you want to run their electronic ignition and high voltage coil, solid core wires are OK to use so long as you use a spiral core wire between the coil and distributor, which I do.
Old 10-28-2012, 01:21 PM
sedanbob's Avatar
Here is the info that came with my ZZ4 (350) crate motor: cyl1: 39.0", cyl2: 41.5", cyl3: 37.0", cyl4: 35.5", cyl5: 32.0", cyl6: 31.5:, cyl7: 30.0", cyl8: 29.0"
The wire looms that came with it route behind the heads, above the headers, then down to the plugs in pairs. ZZ4 uses angled plug heads.
Old 10-28-2012, 04:08 PM
Thanks everyone, I need to look into them a little further seems some people have crossfire problems with them. For the price I think its probably worth a shot.
Old 10-28-2012, 06:40 PM
Wiki Edits: 27
neighborhood interference
the old solid wires with a hot coil would cause problems with TV's when you drove down the street, I don't know if it effects the new electronics. The TIG welder High Frequency also can cause a lot interference proglems.
Old 10-29-2012, 01:45 PM
1971BB427's Avatar
High voltage ignition systems will not only crossfire, but fire to ground with solid core wires. If you're running electronic ignition it wont crossfire, but if it's HEI, or MSD, etc. you can't run solid core wires.
Spark plug wires jumping spark STATUTORY GRAPE Engine 4 10-04-2009 05:14 AM
8 or 8,8 mm spark plug wires? staleg Engine 20 09-08-2007 12:42 PM
Best Spark Plug Wires?? HotRodMan Engine 17 09-27-2005 12:09 AM
spark plug wires oldsF85 Engine 5 03-30-2004 11:00 AM
Spark Plug Wires bg Engine 7 12-26-2002 09:22 PM
