rollcage question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2010, 06:57 AM
72 grabber 51F-1 65 chevystang
rollcage question
I plan to install a cage in my maverick. I am going to buy one of the kits from summit. When welding it in the car does anyone have any ideas on how to avoid burning the headliner
Old 01-02-2010, 07:27 AM
Will I ever get it done?
Last journal entry: Hood
Remove the headliner? Sorry, I couldn't resist.
I am assuming you are talking about the CE C3039 8 point bar kit?
If so, you are concerned about welding the rear struts to the top of the bar?
If it were me, I would do one of the following.
1. See if the main hoop and the rear struts will tilt forward as a unit. Is so, tack the main hoop to the reinforcing plates on the floor. Fit the rear struts and tack them to the main hoop making sure they are in good contact with their mounting points in the rear of the car. Some welders paper will protect the headliner from stray sparks. Cut the tacks at the floor of the main hoop and tilt forward. Finish weld the struts to the main hoop. You should still protect the headliner from spatter.
2. If tilting is not an option, I would drill holes with a hole saw which will allow the main hoop to drop through the floor. The steps are basically the same as above but now when you cut the tacks on the main hoop to the reinforcing plates you will have to slide the reinforcing plates out and let the main hoop drop down.
http://www.3m.com/Product/informatio...ion-Paper.html
Plan ahead and do a lot of dry runs.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
