Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rolled copper tube for compressor line?
Old 08-20-2006, 02:37 PM
SteveU SteveU is offline
After reading of the need to cool air to get the water out I had the following idea but don't know if it would work. Build a support out of wood in a corner of the shop. Take 50' or 100' of 3/4" copper tube and wrap it around the support like a snake climbing a tree securing it to hold it in place. Place a water trap & drain at the bottom and connect the top to airline running across shop to hose reel. I could place fans to blow over this tubing for extra cooling when running hard. Does this sound like it would work & if so, would sweat soldered connections hold up to pressure? I would run a flex rubber hose from the compressor to the copper so vibration shouldn't be a problem.
