-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   rolled copper tube for compressor line? (http://www.hotrodders.com/forum/rolled-copper-tube-compressor-line-96189.html)
SteveU 08-20-2006 02:37 PM
After reading of the need to cool air to get the water out I had the following idea but don't know if it would work. Build a support out of wood in a corner of the shop. Take 50' or 100' of 3/4" copper tube and wrap it around the support like a snake climbing a tree securing it to hold it in place. Place a water trap & drain at the bottom and connect the top to airline running across shop to hose reel. I could place fans to blow over this tubing for extra cooling when running hard. Does this sound like it would work & if so, would sweat soldered connections hold up to pressure? I would run a flex rubber hose from the compressor to the copper so vibration shouldn't be a problem.
Thanks,
Steve
oldred 08-21-2006 08:10 AM
Steve, While that would work (be careful with that soft copper tubing since it really is not suited for this) it may be a case of over-kill. If you have the room to run an ample amount of metal line, over 50 ft, then you probably will not have a problem.
