Roller 383 vs flat tappet 406? - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 08-31-2008, 03:55 PM
Dollar for dollar which would be the better street engine? I currently have a roller set up for a factory roller block in a 350. But suddenly there are 400 blocks everywhere. So what to do. Do I give up the roller cam for 23 cubes. I know you can roller a 400 but is expensive and may do later if money is available. Its going into a light truck and will be a daily driver if fuel dosent go up any more. Will the 400 use gobs more fuel than a 383? i could use a smaller cam with more cubes and make same power? Thoughts.
Quick reply to this message
Old 08-31-2008, 04:07 PM
If fuel counts, then a roller 350 with a "fuelie cam".
Old 08-31-2008, 04:18 PM
Jmark's Avatar
Yes, converting the 400 to roller will cost a lot. If the roller 350 block is in good shape and you can re-use parts in it and money is tight, build it instead to save some bucks.
Mark
Old 09-01-2008, 07:18 AM
The 400 based motor with a FT cam will never disappoint. Stroke it to 3.875 and suddenly the 400 based engine isn't just 23 cubes, it's the 383 + 10%. A FT cam in one of these big small block sings a tune you won't forget.
Old 09-02-2008, 03:23 PM
A stroked 400 comes with a hefty price tag. Money is part of the issue. I like power but not at 8 miles per gallon!
Old 09-02-2008, 05:27 PM
You asked for it, and it ain't Toyota. A stroked 400 is not too hefty a price considering what you get. The parts used are not much more than a run of the mill 383. The 383, compared to a stroked 400 will always leave you with that 'want some' feeling. Also, the TQ of the stroked 400 would make that truck run like a raped ape, and do anything you ever wanted it to. Power comes at a price. If you are looking for mileage I wouldn't do either motor, just a 350 stump puller with standard stuff. IMHO, any truck getting 10MPG is GOOD.
Old 09-02-2008, 08:49 PM
What 400 stroker kit would you recommend or do you piece it together yourself. It sound intrigueing. Does it have the same clearence issues as a 383. How big of heads for street use? My roller 350, desk top dyno 415hp gets 15mpg average driving. If a stroked 400 get half it might be worth it!
Old 02-11-2017, 09:51 AM
Roller 383 vs F.T. 406. Same subject, new questions.
Hello, I have been lurking here for awhile, but this is my first post. I have questions on this same subject, and to maybe help someone searching in the future I decided to just add to this old thread. I've built my fair share of engines but have never built one for this type of application (heavy crew cab truck).
A mild hydraulic roller cam is supposed to make ~ 15 more hp and 20-30 lb-ft more torque than an equivalent F.T. cam. But I have also read that under ~216 deg, a F.T. actually has (maybe using the wrong term) faster ramps than a hyd roller.
A 406 should make ~ 20 more hp and 25-30 lb-ft more torque than an equivalent 383. but will the hyd roller in the 383 make up the difference?
So, my dilemma is, I have both options available to me, and both will cost about the same amount of money to build. The 383 is easier to build, but the 406 would have coolness factor and cubes. This is for a very heavy '99 vortec K2500 CCSB with efi.
Closed Thread
flat tappet hydraulic cams neverfastenuff Engine 1 11-20-2007 07:01 PM
solid flat tappet v/s hydraulic roller 406 ss monte Engine 8 10-31-2006 08:29 AM
opinions and facts: roller or flat tappet??? barbiekiller Engine 11 02-12-2006 03:31 PM
Street Hydraulic Roller Vs Flat Tapet Hydraulic bigjoedo Engine 3 11-25-2002 04:06 PM
engine rayjo Engine 3 04-28-2002 08:22 AM
