Roller block With NON roller cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2010, 09:15 PM
KzyCkr's Avatar
KzyCkr
i have a 97 vortex engine. got it from work as a short block. no cam. bought a new crank, gm X rods an pistons. went to install my double roller timing gear an the chain is rubbing the block. should i buy the stock timing gear setand that will give me the clearance i need???
Crane Energizer Cam PN:100052 is the cam i have and bought to use.
anyone know
brandon
Old 03-13-2010, 09:29 PM
DoubleVision's Avatar
Go to northern auto parts, get the cloyes single roller Vortec timing chain. It`s made for Vortec blocks.
Old 03-14-2010, 10:56 AM
KzyCkr's Avatar
KzyCkr
Vortec timing chain
thanks for the help
Old 03-14-2010, 11:25 AM
KzyCkr's Avatar
KzyCkr
well i looked and its giving me the cam thats for that motor doesn't have the 3 bolt holes for your regular cam. going to our in town HP store and see what they say i'm doing wrong an can't do. :-S
Old 03-14-2010, 11:55 AM
I built a 383 using a late model block, had to grind it in that area to use the double roller chain.
Old 03-14-2010, 12:20 PM
You can`t go by the picture. I`ve built several Vortec engines so I know what they use.
http://www.jegs.com/i/Cloyes/220/9-3157/10002/-1
This is from Jegs and the part number is the same as the one at Northern.
http://www.northernautoparts.com/Pro...tModelId=19299
The 3157 is the more expensive model, the 1157 is the less expensive model and works just the same:
http://www.summitracing.com/parts/CLO-9-1157
disappointed in new block nskeeter99 Engine 3 01-27-2009 09:05 PM
BBC gen 6 roller cam! Studebaker Engine 1 01-04-2008 07:13 AM
Roller Cam Install - Cam Button & Timing Cover Help leejoy Engine 10 12-01-2007 04:28 PM
Soild Roller Or Just Roller Maybe Just Soild Cam? Best For Me tiresmoke55 Engine 23 08-22-2007 11:38 PM
roller cam in an non roller block..is it possible? bigshow2 Engine 5 09-18-2005 07:31 PM
