RolLeR BloCkS WitH MECH. fuel pumps? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2010, 06:54 PM
someone said gm does make some roller blocks with the proper machining for a mech. fuel pump? does anyone know what years or castings i should be looking for?
Old 08-12-2010, 07:53 PM
Not from production, you'd have to go to GMPP for a Production based race block to get the combination of features you're seeking, something like 10066034 would build you a 2 piece rear seal 350 with a factory roller cam as well as a mechanical fuel pump provisions all machined and ready to go. Or use 10105123 for a one piece rear seal crank with the same provisions.
Lookie here: http://www.jrgmparts.com/GM_Performa...y_small_b.html
Bogie
Old 08-12-2010, 07:58 PM
BOBCRMAN@aol.com's Avatar
Check Marine usage. Blocks are rare and expensive.
Old 08-12-2010, 08:01 PM
Sinister's Avatar
Check out Summit's stroker blocks. 1 piece rear main seal, roller blocks, with provisions for a mechanical fuel pump.
http://www.summitracing.com/parts/SUM-150100/
Old 08-12-2010, 08:20 PM
All of the ZZ series SBC's I have owned and ever seen had the provision for a mechanical fuel pump.
Both of my ZZ430's , my ZZ4 and my ZZZ Chevrolet crate engines have provisions for the mechanical fuel pump.
part number # 12561723
This partial engine includes the ZZ4's forged
steel crankshaft and comes with LT1-style pistons
and connecting rods. It does not include the camshaft,
cylinder heads, lifters, timing set, front cover, oil pump,
oil pan, balancer, or flexplate.
The block is available separately also
part # 10105123
Cast iron 4-bolt block 1 piece rear main seal
4.00 bore
Machined for hydraulic roller or flat tappets
Old 08-12-2010, 08:23 PM
hemi joe's Avatar
loves ex cop cars
i have a mech.pump on my 1987 chevy caprice 5.7L/350 roller block.it's factory,if that helps you.my car is carbureted.
woah thanks for all the help lol. but im on a BUDGET haha.
Old 08-12-2010, 08:25 PM
im looking to spend about 700-800 for the short block...
Old 08-13-2010, 07:15 AM
There were factory blocks with the fuel pump boss and roller cam setup, you just have to do some digging. They weren't all on carb'ed vehicles during the transition period either, some came with a block plate on it.
OTOH, almost all of the roller blocks have the flat area machined and one 3/8-16 hole drilled and tapped. I built a fixture to come off that hole and drill those blocks for a mechanical fuel pump for quite a few circle track guys in certain situations. It takes some silly long drills and tooling, but if you look around I would think you could find a shop capable of doing it.
Old 08-13-2010, 03:51 PM
FastOrange's Avatar
my 638 block is machined for it, out of a 1990 Burb (73-87 style)
but my other 638 block is from a 1994 K1500 and doesn't have it.
so its hit and miss, you have to hunt for one, ive had 4 One-Piece blocks go through my hands, each one was different in its one way.
Old 08-25-2010, 08:40 PM
If I were hitting the yards looking for a block, I'd take an old fuel pump push rod with me to test them with. I've heard that some of them are not completely machined for the rod, even if there's a hole present.
Old 08-25-2010, 10:16 PM
FastOrange's Avatar
true, i had a 1988 block that wasn't fully machined. and my 1990 block is
Old 08-26-2010, 06:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Your best chances will be w/880 and 638 blocks. Others may be machined for the mechanical pump, but these two are definitely available w/the pump hole finished- as well as unfinished, so you still need to check.
The one shown below is a 880 block, w/o finished mechanical fuel pump mounting.
Name:	FUEL PUMP BOSS 880 Block.jpg
The Following User Says Thank You to cobalt327 For This Useful Post:
0trbo4myCHEVUICK (06-13-2013)
Old 08-26-2010, 06:30 AM
malc's Avatar
Living At The Speed Of Life
My shortblock came with that same problem, the pump pushrod hole was partially drilled.
As the block had come from America to Spain I was´nt about to return it for another so I drilled it out myself.
I wadded up the drill bit and all around the area with grease to catch the swarf.
mech to elec fuel pump crussell85 General Rodding Tech 21 08-15-2010 10:28 PM
Electric Fuel Pumps JAMES MEDLEY Engine 2 08-24-2009 08:21 PM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 03:36 PM
fuel tank mod for duel pumps? curtg21 Engine 0 12-17-2006 11:31 AM
Electric fuel pumps....for a boat WakBordr7387 Engine 5 10-23-2006 08:10 AM
