roller cam for bbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2009, 06:44 PM
85 k5 mud truck's Avatar
****** bowtie
roller cam for bbc
ok so i had a soild roller comp cam .626/626 installed. does anyone no what might the vavle lash setting be to try to keep it around
Old 07-27-2009, 06:47 PM
ericnova72's Avatar
More for Less Racer
It is listed on the cam card that comes with the cam.
Old 07-27-2009, 10:54 PM
techinspector1's Avatar
Wiki Edits: 326
The widest lash used on any CompCam solid roller is 0.028" intake hot, 0.030" exhaust hot. If I had a cam installed that didn't have a cam card with it, that's where I'd set them to start. Then I'd tighten 'em up a little at a time until I burned a valve, then back off a little. NO, NO, just kidding.
Get the number off the stick and call Comp.
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 05:21 PM
roller cam retro fit DARIN ALLMAN Engine 14 12-17-2007 04:29 PM
What type cam gear speedpro roller cam # CS1071R straydog Engine 0 07-07-2007 08:58 AM
flat tappet to roller cam toddtheodd Engine 29 02-06-2007 06:06 PM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 04:29 PM
