Roller Cam Bearings????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2002, 07:00 PM
chevyelc81's Avatar
Post Roller Cam Bearings?????
I was reading an artical about a guy using roller cam bearings. I guess you need a special cam for them, but is it worth it for the street?? Is there really a noticable difference and is it reliable?? Also, where can you get a roller cam and bearing set up? any info will help, thanx alot.
Old 11-19-2002, 07:09 PM
BOBCRMAN@aol.com's Avatar
Post
makes good reading, and sells magazines but unless you have a couple thousand dollars burning a hole in your pocket, not practical,plain bearings have almost no friction when running,
Old 11-19-2002, 07:19 PM
woodz428's Avatar
Troll Hunter
Post
Ditto, with all the extra machining required and the return you'd get it isn't worth the expense.
Old 11-20-2002, 05:47 AM
engineczar's Avatar
Post
SBC's with Roller cams are typically only used in VERY high end motors. Winston Cup, Busch, NHRA Comp eliminator. We have a customer that runs a C/SM Camaro here in Division 1 and unless your pockets are bottomless than your money is best spent elsewhere. We run them in that application because of the nearly 1 inch of valve lift required.
BSE Racing Engines
