Roller cam break-in? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2003, 06:18 AM
I have chosen a Comp solid roller for my engine build and also have double springs with about 190lbs of seat pressure. I have heared that when using heavy springs you should run the cam in (about 20mins at 2500rpm) without the inner springs installed. But I am pretty sure that rollers don't need any run-in time. Should I just install both inners and outers and go for it, or is there still a break-in period?
Also do I still need to use moly lube on the lobes?
Thanks.
Old 10-08-2003, 06:59 AM
Bumpstick's Avatar
Hammer and a torch
No need for "break in" on a roller cam but the use of moly lube is recommended... Just remember after running the engine at operating temp after startup and shutdown to allow it to cool and R&R the oil filter as the moly lube will gel up in the filter and possibly plug it...
Old 10-08-2003, 12:34 PM
abe abe is offline
Both solid and hydraulic roller cams DO NOT require break in. Yes go and use both inner and outer springs when u start it up for the first time. And always use a moly lube on the cam and lifters. Darn i love cams that dont need a break in.
Old 10-08-2003, 05:01 PM
western star's Avatar
OK I'll bite. Why no break in for roller cams? Oh wait. Is it because the lifters always run the same pattern? I know very little about rollers. Only that they are more expensive.
