If all he's doing is a cam swap, he can go straight to the drag strip. Roller cams and lifters require no break in, that's the beauty. If there are new rings to seat, then a normal break in period is warranted.
If you are going solid roller then there is a type of break in you want to abide by. Solids need to be lashed hot. So the base setting you lash at cold will need to be slightly tighter on an iron/iron combination and way tighter on an aluminium/aluminium combination. So if the lash is around .020/.024 on a iron head iron block combo I'd set around .016/.020. If it was an aluminum head and aluminium block I'd be in the .010/.012 range. Lots of growth occurs from cold to hot. After the motor gets hot and up to operating temp on the water AND oil, then the lash has to be run and set to proper specs.
Cold starting points should be verified with the camshaft manufacturer, but will always be less than the hot spec. If your too loose on the initial lash you can bang up the lifters and ramp of the camshaft. |
| Can i use Castrol for my cam break in??? | Mike_82 | Engine | 7 | 02-22-2004 07:05 PM |
| Roller cam | 2wld4u | Engine | 9 | 09-25-2003 09:11 AM |
| solid roller cam...lifter broke! | chevyelc81 | Engine | 7 | 09-05-2003 01:41 AM |
| Roller Cam Conversion | meschnebly | Engine | 7 | 07-15-2003 07:26 PM |
| Roller Cam | erik350 | Engine | 3 | 05-12-2003 11:12 PM |
