-   -   Roller cam choices (http://www.hotrodders.com/forum/roller-cam-choices-203250.html)
s10junkie 08-05-2011 09:44 PM
Roller cam choices
I have a 350 4 bolt main engine with double hump heads,eldebrock intake,2500 stahl and hedman headers. I am looking to convert over to a roller cam set up and need help chooseing the right size cam. I know comp cams can advise me on the right cam but I would feel better getting this information from someone who already has this set up. The engine is currently in a Chevy S10. Thanks
cool rockin daddy 08-05-2011 10:04 PM
You have a belly button chevy 350. Everybody's got one. Go with what Lunati, Comp, or Isky tell you. Can't go wrong.
s10junkie 08-05-2011 11:33 PM
Roller cam choice
Thanks for the reply
ericnova72 08-06-2011 02:44 PM
Hydraulic roller or Solid roller? (Girlie or Manly? :P )
joelster 08-06-2011 02:55 PM
Those heads don't flow near enough to fully take advantage of what a good roller cam can offer you. All of those companies are going to ask you a bunch of questions first. What type of driving, what is the compression, what springs, what size carb, etc, etc....
I'd rock something along a 220ish duration with .480"ish lift.
