Roller cam choices - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2011, 08:44 PM
Roller cam choices
I have a 350 4 bolt main engine with double hump heads,eldebrock intake,2500 stahl and hedman headers. I am looking to convert over to a roller cam set up and need help chooseing the right size cam. I know comp cams can advise me on the right cam but I would feel better getting this information from someone who already has this set up. The engine is currently in a Chevy S10. Thanks
Old 08-05-2011, 09:04 PM
cool rockin daddy's Avatar
You have a belly button chevy 350. Everybody's got one. Go with what Lunati, Comp, or Isky tell you. Can't go wrong.
Old 08-05-2011, 10:33 PM
Roller cam choice
Thanks for the reply
Old 08-06-2011, 01:44 PM
ericnova72's Avatar
More for Less Racer
Hydraulic roller or Solid roller? (Girlie or Manly? )
Old 08-06-2011, 01:55 PM
Those heads don't flow near enough to fully take advantage of what a good roller cam can offer you. All of those companies are going to ask you a bunch of questions first. What type of driving, what is the compression, what springs, what size carb, etc, etc....
I'd rock something along a 220ish duration with .480"ish lift.
SBC Factory roller lifter retro on non roller block 383ram Engine 1 01-24-2009 07:16 PM
plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? tiresmoke55 Engine 20 05-24-2006 01:51 AM
Roller cam choices. 355 SBC Jared Engine 14 07-04-2005 12:09 PM
Choices, Choices..... I need opinions Centerline Hotrodders' Lounge 6 04-02-2004 10:16 AM
Hemi update and choices, choices! HemmiGremmie Hotrodders' Lounge 3 09-07-2002 08:54 PM
