Roller Cam / Lifters in Gen IV 454 Block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2009, 10:20 PM
31fordcoupe's Avatar
Last journal entry: Gunked up 454 water jacket
I guess I need to know if there are any known problems / limitations of running a hyraulic roller cam and lifters in a Gen IV 454 block? Any limitations on lift or duration with the roller cam and lifters in a Gen IV 454 block when compared to a flat tappet hydraulic or solid lifter cam? Thanks.
Brent
Old 03-12-2009, 02:38 AM
techinspector1's Avatar
Wiki Edits: 326
Only problem/limitation I can foresee would be getting me to pull all those Franklins from my wallet to buy the parts.
Old 03-12-2009, 07:08 AM
Guy Hiltz's Avatar
AFAIK,there are no limitations on the amount of lift & duration,although personally,I would not use a hydraulic roller.A correctly matched solid lifter setup will require very little regular maintenance/lash adjustment,and will allow for more performance gain,IMO.
Guy
will this cam work well? STLrocker Engine 9 03-29-2009 08:39 PM
Hyd Roller Cam W/Solid Roller Lifters? RoyLeoGracie Engine 11 02-03-2009 10:15 AM
Installing Roller Camshaft in Mark IV Big Block - What Mods are Required? leejoy Engine 23 12-18-2007 03:51 PM
Gen V heads, Mark VI block SteveJ44 Engine 1 11-14-2004 09:14 AM
Big Block chevy cam help deuce_454 Engine 4 05-20-2002 12:15 PM
