Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 03-11-2005, 07:53 PM
brainsboy's Avatar
brainsboy brainsboy is offline
brains
Roller Cam Noise?
Im working on a 351w stroked to a 408. I have a crane Hyd roller cam and the valve train started making alot of noise. It sounds like a solid cam now with about .030 clearance. I checked all the rockers and everything is set to 1/2. Are Hyd roller cams supposed to be noisy?
Ben
  #2
Old 03-11-2005, 08:08 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
No they aren't.
Old 03-11-2005, 08:10 PM
brainsboy's Avatar
brains
Then anyone have a shot gun so I can shoot my motor then myself, Im completely tired of all these crap problems ARGGG, crapola im pissed...
Old 03-11-2005, 08:16 PM
lluciano77's Avatar
That is what it is all about.
Are you running stock heads? If so are they supposed to have lash caps on the valves? Are the lash caps missing?
Old 03-11-2005, 09:01 PM
brainsboy's Avatar
brains
408 stroker windsor
Aluminum 215cc runner heads
2.08/1.60 SS racing valves
Crane cams hyd roller lifters
Crane cam 224/.568lift 112cl.
I pulled the intake off, and inspected all the lifters, other then surface scratches they all look the same and ok. Cam lobes look ok. Rocker arms are ok. Oil pressure is perfect. Everything seems ok.
Could having too much spring pressure cause the lifters to be noisy? I am running to the max for spring pressure according to crane cam specs.
Old 03-11-2005, 09:10 PM
HemmiGremmie's Avatar
HemmiGremmie HemmiGremmie is offline
Last journal entry: 52 truck
I feel yer pain.
I was wanting to off myself about a week ago to. It gets frustrating. Hang in there. HG
Old 03-11-2005, 09:19 PM
redlightning's Avatar
redlightning redlightning is offline
<<<< My son is a US Soldier
Brainsboy,I have read at the lightning site about valve train noise I can,t remember the answer.You might take a look over there it is nloc.net then go to the gen 1 forum.Those guys are 351w,s fanatics.
Old 03-11-2005, 09:20 PM
coldknock's Avatar
coldknock coldknock is offline
It's possible that the springs are too stiff and causing the lifters to collapse.
Larry
Old 03-12-2005, 02:26 AM
KULTULZ KULTULZ is offline
aka Duke of URL
Most likely the valvetrain wasn't setup correctly;
-Push Rod Length And Valvetrain Geometry-
Once this is determined, there is a special procedure for establishing valve lash.
Old 03-12-2005, 12:31 PM
brainsboy's Avatar
brains
I went through 3 sets of pushrods before I got the right length, I just rechecked the wear marks on the valves look fine.
I went to my machine shop this morning they said that those lifters can take alot more pressure then what I'm set up at. He thinks that because I dont have a retro-fit cam for the 69windsor block that the newer style cams have whats called a larger diameter lobe and lift sits too far out. Where this may be true my lifters are not coming out of the bore, and crane lists my camshaft for the 69-90's, so I dont know what to do
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Roller Cam Noise?"
ThreadThread StarterForumRepliesLast Post
block mod for roller cam?Rocket455Engine803-14-2004 08:16 AM
Installing Comp Cam Roller Rockers on 5.0L Ford Motorsports GT-40mikebmacEngine207-23-2003 11:22 PM
IGNITION and CAM TIMINGsum87mustangEngine307-11-2003 08:52 PM
roller cam ----springs???rookieEngine203-16-2003 10:25 PM
Roller Cam Help!!!VsanthosEngine1310-31-2002 05:29 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
