We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 09-13-2005, 06:54 PM
bigshow2's Avatar
bigshow2 bigshow2 is offline
Objects in mirror are losing..
roller cam in an non roller block..is it possible?
I have in my posession a 1993 K motor out of a K1500 Suburban that I am building to put in my 1969 Nova. My question is I snagged a freebie from a Chevy dealership I was working at in the form of a cam,rocker spring and accessories. Part #12480002 in the GM performance parts division. Will I be able to put this cam in my block using roller lifters and retainers? The block originally had flat tappet lifters. Or will I have to get some retro kit. I also have an R motor block (Vortec) laying around. Should I use the R motor instead of the K motor? Any help here will be greatly appreciated. I am building this motor out of used parts and a very squeaky budget,and I got the cam and 1.6 rockers for free so im anxious to use them.
Thanx all...
Old 09-13-2005, 07:10 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
Some of the K engines had the bosses for the factory roller cams and even some were already drilled for the bolts (for the hold down alignment hardware for the roller lifters)... The Vortec for sure does have the bosses and are drilled and ready as this is how they came...
Old 09-14-2005, 07:13 PM
1964chevelle's Avatar
1964chevelle 1964chevelle is offline
its not pink its ember red
what size is the cam?
Old 09-15-2005, 10:33 PM
jimfulco jimfulco is offline
That's the GM LT4 "HOT" cam kit. .525" lift with 1.6 rockers, duration @ .050 is 218*/228*, LSA is 112*.
Be sure you use the melonized distributor gear (pn 10456413)with the GM roller cam.
You'll need GM's roller lifter conversion kit (pn 12371042), pushrod kit (pn 12371041), and a timing chain kit (pn 12371043), or equivalent parts from a junkyard 350 or 305 roller motor. Go to www.sdpc2000.com and search out those part numbers for details.
The '93 heads will have to be modified for that much valve lift and possibly for the new valve springs (1.32" diameter). Screw-in rocker studs might also be a good idea.
Check the block to see if it will accept a fuel pump pushrod. Some of the later roller blocks will take a mechanical pump, but not the pushrod that operates it. If not, you'll need an electric pump.
If all this seems too complicated, just send the free cam kit to me.
Old 09-16-2005, 03:41 PM
bigshow2's Avatar
reply
TO jimfulco....
I appreciate your info.. I guess I forgot to mention that I also have the "R" motor heads that will be going on this engine. I may be slow but I aint no dummy..lol. Anyhoo your sayin I will still need a roller conversion kit eh? I will use your advice an check that out. I've built many a small blok in my career but i've never converted a non roller to a roller,so I wanna make sure I dont blow up my motor. Like I said earlier I got a squeaky budget tryin to make my dads dream of having a hot rod Nova vome true. Thanks again for the advice and help.
Old 09-18-2005, 07:31 PM
Might check ebay for used parts. I found some stuff pretty cheap last year, but it's kinda sporadic. GM has some newer-design lifter guides (pn 88958652) that make it possible to change the cam without pulling the intake. They cost $25 but I bet it would be a time-saver.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "roller cam in an non roller block..is it possible?"
Can i have my solid roller cam re-ground? shockers69 Engine 1 04-19-2004 07:41 PM
roller cam selection Jared Engine 2 10-28-2003 02:27 PM
Roller Cam Conversion meschnebly Engine 7 07-15-2003 07:26 PM
Roller Cam Conversion lakecityg Engine 3 07-15-2003 02:11 AM
roller cam smallblocked_S-10 Engine 1 08-31-2002 09:48 PM
