roller cam or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2010, 01:10 PM
hemi joe's Avatar
loves ex cop cars
roller cam or not?
hey guys,i'am trying to find out if my motor is a roller cam or not.87 chevy caprice 5.7L/350 ex police car original factory motor,i got these numbers off of head after removing valve cover,14101083,checked push rod length 7.180" with verniers.does this help anyone to identify if a roller cam or do i need more info.please let me know,thanks joe.
Old 01-27-2010, 01:22 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Hey Joe, You need the casting # off the block it might be a roller engine they had them in your year but really need the #, You do have a decent set of 64cc heads though.JMO
Cole
Old 01-27-2010, 01:26 PM
hemi joe's Avatar
loves ex cop cars
thanks cole,still trying to find number off of block.
Old 01-27-2010, 01:33 PM
eloc431962's Avatar
Wiki Edits: 37
Look behind the distributer where the bellhousing meets the block there is a flat place on the block # should be there.
Cole
Old 01-27-2010, 02:11 PM
hemi joe's Avatar
loves ex cop cars
ok,this is the number i found on back of block behind dist. kind of on pass. side#14c93638,also found on front under alternator#v0413sea don't know if this helps.thanks joe.
Old 01-27-2010, 02:35 PM
Banned
back up. pushrod length... PUSHROD LENGTH...
Old 01-27-2010, 02:37 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
the serial number is actaully 14093638 gm 350 block made from 86'-95', my research shows that they made it in both 2bolt and 4bolt mains, and that it had a 1 piece rear main seal, but the wierd thing is that i show that it was made with both flat lifters and hyd roller lifters. i didn't know that gm did this, i guess the only way to really tell would be to pull the inake off and take a look at the lifters them selves, i'm sorry i couldn't actaully give you an answer
Old 01-27-2010, 02:44 PM
hemi joe's Avatar
loves ex cop cars
ap72,what do you mean...PUSH ROD LENTH?
Old 01-27-2010, 02:45 PM
Hippie's Avatar
Last journal entry: HEI comparison.
My new roller cam push rods measure the same, my money says it's a roller motor.
Old 01-27-2010, 02:47 PM
Banned
Hippie won the prize!
BTW, my spelling is terrible, which is why I am not a writer.
7.2"+/- is standard for a factory roller cam in a sbc.
Old 01-27-2010, 02:49 PM
my87Z's Avatar
oh crap i completely over looked that part of the original post. if you have "7.180" push rods they should really be 7.195" for an OE roller, but there is your answer right there, cause std length flat tappit pushrods are 7.800" so you have a roller block/valve train
Old 01-27-2010, 02:51 PM
my87Z's Avatar
darn i was like 2 seconds late
Old 01-27-2010, 02:59 PM
eloc431962's Avatar
Wiki Edits: 37
I completely over looked that also.
But now you know Joe.
Cole
hemi joe's Avatar
loves ex cop cars
thanks guys for all your help i've been trying to find if this was a roller cam without tearing down motor.thanks again,joe
Old 01-27-2010, 03:03 PM
my87Z's Avatar
no prob joe
Hyd. Roller lifters on Solid roller cam danrace1 Engine 6 01-28-2010 05:21 PM
solid roller make more power than my flat tappet cam? jarrettandroski Engine 31 11-23-2009 11:55 AM
Flat cam in F4 Roller Block Carlos9 Engine 2 11-12-2009 09:21 PM
flat tappet to roller cam toddtheodd Engine 29 02-06-2007 06:06 PM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 04:29 PM
