Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller cam retro fit
Old 12-17-2007, 01:18 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
NonRoller Block
Originally Posted by oldbogie
Yes, but first let me dump a little background.
The ZZ4 cam and all factory passenger car and some truck cams since 1987 are for the OEM roller config which uses block modifications; these being taller lifter blocks, cast and machined bosses on the main oil galley that mount an eight legged spider used to retain pair wise sets of bars that hold the roller lifters in alignment. The front of the block is modified to accept a cam retention plate that bolts on with 2 bolts to a pad added around the face of the front cam bearing. This requires a cam with a machined nose the thickness of the plate. The cam's timing gear hub is modified to accommodate the additional thickness of the plate and cam nose without moving it's position relative to the crank gear.
The solution on the front is to purchase the thrust plate and cut its ears off and to use the timing set for the OEM roller engine with a cam button to retain the roller cam.
But in the bigger scheme, while there are people who modify non roller blocks to roller use, it requires drilling and tapping into the main oil galley for spider retention bolts, this really isn't thick enough for the loads, and passing the bolt thru the oil galley would significantly reduce oil flow. The lifter blocks are also about 1/4 to 3/8s inch too short to adequately support OEM rollers. So I can't really recommend trying to put an OEM roller into a non-OEM roller block, just too many iffy compromises to suit me.
Now you could use aftermarket roller lifters but these are rather expensive. So by the time you do all this messing around, you might just as well pick up a roller block. For 350 roller tappet blocks look for casting numbers 10243880, 14011148, 14088526, and 14093638. The 880 is pretty common as it's the Vortec truck block.
Bogie
Hi Bogie, It's a little work but it actually works great. The bolts/studs go just to the inner edge of the oil gallery. I Epoxy around the jamnut also. Also the 2.2 L4, 3.1V6,3.4V6 Roller lifters are .200 shorter than V8 Rollers do that takes care of most of the lifter boss Diff. Send me an email and I'll send the RetroRoller Instructions AdobeAcrobat 3.5MB file 55pages.
