Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller cam retrofit
Old 02-28-2008, 06:12 PM
PatM PatM is offline
If the original engine came with a roller cam, do not use a retrofit. If the original engine came with a flat tappet cam, use a retrofit roller. Naturally, this all assumes that you're not specifically modifieing the block at the machine shop for the OEM type cam configuration.
Pat
