Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roller cam retrofit
Old 02-28-2008, 06:17 PM
y112 y112 is offline
roller cam
As far as any roller "fitting", they will. Some people think that the newer factory ones won't fit the older blocks, but that is not true. The factory cams have a smaller diameter end that was machined for the factory retainer plate that bolted to the block. The overall length is the same. Anytime you use a roller, you must control the endplay of the cam to prevent the roller lifters from hitting the adjacent lobes. This is done with a cam button on the older engines and a retaining plate on the newer engines. You can use a cam button on a newer factory roller in an older block.
The timing gears fit the same.
If you use a hydraulic roller in an older block, YOU MUST use the aftermarket lifters because the old blocks are not machined for the newer factory lifters and retainers.
You MUST match up components for the blower motor and I highly recommend calling one of the several tech lines available through Crane, comp cams, Lunati etc. for the best selection. So-called dumb questions are a lot cheaper than a mis-matched engine that runs like a pig.
After you determine how your vehicle will be driven most of the time, then you can start putting your plan together.
Tire size, gear ratio, trans, vehicle weight and rpm range info will be needed before you call the tech line.
Don't forget to consider the strength of the rear, trans, and axles that you will be using with the blower.
Hope to see some photos!
