The button is called a "thrust" button. It goes onto the front of the camshaft and butts up against the timing cover. It prevents the cam from walking too far forward out of the block since you don't have a retainer plate like a factory roller block would have. An sbc roller cam also has a slightly smaller bolt pattern for the timing chain. You already have most of the pieces though. Cam, lifters, spider, dogbones, then you need pushrods, timing chain, thrust button, and springs.
Is the retainer plate attached by 2 bolts? There are one on each side of the camshaft tunnel/bore. They are located right behind the timing gear. I have these, they were drilled and tapped and I wondered if that is what their use was. The springs I have are Howard and they are listed to work for flat tappet/ hyd roller.
This is a photo I found online. This is the retainer plate and where it attaches right?
There are at least two different retainer plates. The difference is the center distance between the bolt holes. I forget the specifics as to which is for what year, but you can find the info if you do a search on my posts.
FWIW ssmonty |
Thanks for the info ssmonty. I have just about everything, just have to get a retainer plate, pushrods after I measure for them. I am pretty sure 7.2 in p rods will work since the stock hyd flat tappet p rods worked for the current cam but I suppose it is better to measure and know for sure. I also need the cam of course. What about the distributor gear? Do I need to get another gear? I have read some roller cams are compatible with the stock gear. I guess I should ask Comp before I order the cam. Again thanks for the help everyone.
Hardened distributor gear
GM introdouced a case hardened (melonized) iron distributor gear for the austempered ductile iron roller tappet camshafts and OE distributors, part number 10456413. That gear is also compatible with aftermarket austempered ductile iron hydraulic roller and flame hardened flat tappet iron camshafts. You should use a new distributor gear with a new camshaft.
Steel billet camshafts require a sacrificial bronze gear because an iron gear would eat up the steel billet cam gear in a few miles. Steel billet camshafts are only used with mega-lift solid roller and solid flat tappet cams. No hydraulic lifter camshaft is a steel billet. |
Just thought I'd mention that the GM gear is for a stock distributor shaft diameter of .493" I believe. It won't fit a MSD dizzy(1/2" shaft). They have thier own melonized gear PN MSD-8561. Ask me how I know.
I also thought I'd mention that if you plan on going with a double row timing chain you'll have to do a little grinding. FWIW ssmonty Last edited by ssmonty; 08-06-2011 at 05:35 PM. |
Gear
When I wrote "OE distributors" I should have wrote, "original equipment distributors."
| Solid roller to hydraulic roller cam questions | Hoonbash | Engine | 1 | 03-23-2009 07:06 PM |
| SBC Factory roller lifter retro on non roller block | 383ram | Engine | 1 | 01-24-2009 07:16 PM |
| Roller Rockers Question - Roller Pin Coming Out | leejoy | Engine | 9 | 11-27-2008 12:52 AM |
| plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? | tiresmoke55 | Engine | 20 | 05-24-2006 01:51 AM |
| Which is better Hydrallic Roller or Solid,Mechanical roller | dboyett38666 | Engine | 4 | 04-02-2006 08:59 AM |
