Roller Cam Suggestions
Hello,
I am considering switching to a roller cam in my Nova. The current setup is as follows. Engine: 350 9.5:1 Trickflow Specialties 23degree heads. (195 runners, 2.02 intake 1.60 exhaust) Rpm Airgap Speed Demon 750 MSD pro-billit HEI + 6AL Full length headers Drive train: M-20 8.5 10-bolt 3:73 My current cam is a 280H from comp and I am happy with it but of course would like more. I could get way more lift out of those heads and a roller is the only good way to do it without huge durations. Any suggestions for a cam would be great. |
Most likely hydraulic but mechanical is not ruled out. It will be street use.
I dont know how much of a rough idle you are willing to deal with, or if you have power brakes, but as far as a good match to the heads and cam,If you did not mind going with a solid roller, I would recommend the XR276R (236 242 @.050 .564 .570 or .594 .600 with 1.6 rockers) or the extreem energy hyd roller with the same duration at .050 and the 1.6's. The solid roller would make more hp, but you would have to set valve lash every once in a while. I think this cam would be fairly choppy at idle, and may not provide a whole lot of vacuum, but it should perform well. If you are happy with the responsiveness of your current cam, you could go with a roller with the same duration at .050 and add some 1.6 rockers. For example, the xr282hr (230 236 @.050 .540 .550 with 1.6's) or the xr268r (230 236 @.050 .552 .564, .582 .594 with 1.6's). One last idea to consider; If you like how the single pattern cam works, and want a hyd roller the 286HR (230 @.050 .590 lift with 1.6's) would would give you the lift, but keep the duration similar to what you have now to retain driveability. I would recommend a dual pattern based on the flow data given on the site below. According to comp cams, unless your exhaust to intake ratio is around 75%- 80% minimum, a dual pattern cam will be beneficial. Also, 454C10 made some good points about the added costs of a roller cam.
http://www.chevyhiperformance.com/te...se/index5.html Adam |
Yeah I have heard of the 4-7 swap cam.
Ok new question. As mentioned before stroking to engine may be a better option. So with my combo what do you guys think would provide the best bang for the buck? |
| Roller Cam suggestion | NovaSS350 | Engine | 0 | 09-24-2006 08:27 PM |
| Mildly Built 383... Cam Suggestions? | Dizturbed One | Engine | 12 | 11-03-2004 03:29 PM |
| bbc roller cam springs??? | k-star | Engine | 1 | 04-24-2004 09:04 AM |
| roller cam selection | Jared | Engine | 2 | 10-28-2003 02:27 PM |
| Roller Cam | erik350 | Engine | 3 | 05-12-2003 11:12 PM |
