roller cam upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2010, 05:43 PM
roller cam upgrade
I have a flat tappet hyd cam fitted now, but what parts apart from cam, lifters, pushrods and springs will I need to upgrade to a hyd roller cam? (ie the parts that stop the cam moving forwards/backwards and will I need a different timing cover?)
The block is post 1987 SBC so machined for the retainer plate.
Part numbers would be helpful.
Also I am using Valvoline racing oil 20/50 at the moment - would another type of oil be any better with a roller cam?
Old 12-21-2010, 08:36 PM
Don't know about the oil, the part to limit cam movement is called a block protector. Summit part number SUM-G1790 and are 12 bucks
there's also a cam button pn sum-g001 and are 3 to 7 bucks each.
Timing cover needs to be stronger to limit cam walk. They make em with the button in em but they're expensire such as pn clo-9-221
Old 12-21-2010, 09:51 PM
ericnova72's Avatar
More for Less Racer
The block should have the cast bosses for the camshaft retainer plate behind the timing gear, might need to be drulled and tapped. You'll need the plate and the timing chain/gears compatable with the roller cam and retainer plate. With this set-up you won't need a cam button or aftermarket timing cover. If not using a factory cam retainer you will need a cam button and strong cover to prevent cam movement forward in the block.
You will need the lifter spider reatainer and the lifter dogbones if using factory style roller lifters. You could use retro-fit link bar roller lifters and not need the factory dogbones and retainer spider of you don't want to use factory parts.
Oil weight won't matter, you can keep using 20W50 if you like.
Old 12-22-2010, 12:58 AM
Thanks for the replies.
Due to the distributor gear/oil pump drive, will the cam want to "walk" forwards or backwards in the block?
Re engine oil - the Valvoline Racing oil is a mineral oil containing old fashioned zinc for flat tappet cams. Will I still need to keep using mineral oil with the roller cam?
Old 12-22-2010, 10:10 AM
Last journal entry: Paint
Don't forget to change the distributor gear.
Oil Restrictors with Solid roller cam and roller rockers RippinRon Engine 8 05-16-2010 10:15 AM
SBC Factory roller lifter retro on non roller block 383ram Engine 1 01-24-2009 07:16 PM
Roller Rockers Question - Roller Pin Coming Out leejoy Engine 9 11-27-2008 12:52 AM
plz help,,,1988 vette 350 hyd roller motor can i convert it to hyd non-roller?? tiresmoke55 Engine 20 05-24-2006 01:51 AM
Solid Roller Setup/Best roller lifters? fearsomefairmont Engine 1 06-26-2004 06:41 PM
